« : 26 Март 2008, 10:55:10 » |
От кого: Игорь М Кому: akonov@ri, falk@ri, nech@nirfi, dugin@nirfi, g.tuccari@ira, s.montebugnoli@ira, liux@uao, harlamov@okbmei, volvach@, v.agapov@, shmeld@, g.pupillo@isac. Дата: 26 Мар 2008 02:33:05 Тема: VLBI radar session of 2008 Dear colleagues,
We propose to arrange annual VLBI radar session of 2008 between September 2 and 11.
Please let us know your opinion without delay - deadline for proposal on Italian antennas is April 1.
In principle, asteroid 2000DP107 will approach to Earth on September 11, but not too close (~8 mln. km).
Main goal of our next session may be space debris, and may be some from the Earth group planet.
Best regards, Igor
« Ответ #1 : 26 Март 2008, 10:55:38 » |
Здравствуй, Игорь!
С датами согласны.
Но наблюдать планеты, видимо, не удастся. Ближе остальных Меркурий (160 млн.км), но диаметр маловат. Подходящих астероидов тоже не вижу.
Маша
« Ответ #2 : 26 Март 2008, 10:56:10 » |
Hi Igor,
it is basiclly ok for Urumqi, let us know timeline one month before observation.
cheers Liu
« Ответ #3 : 26 Март 2008, 18:01:42 » |
Dear Igor,
on Sep 02 we have a geo experiment so we could start one day later.
Cheers, Gino
« Ответ #4 : 26 Март 2008, 19:39:08 » |
Hi All, There isn't nothing else planned on that time so far. However JENAM is planned in Vienna on that time and I would like to attend. Session partly will run without me... What about processing of previous results? Ivar
« Ответ #5 : 26 Март 2008, 21:57:12 » |
Hi Ivar!
S> There isn't nothing else planned on that time so far.However JENAM is S> planned in Vienna on that time and I would like to attend. Session S> partly will run without me...
OK, I see
S> What about processing of previous results?
The processing is not finished still, but we plan to make this prior to September session. In part of processing we are working on three experiments now: VLBR07.2, VLBR07.1 and VLBR06.1.
Unfortunately, last year sessions were not too successful. In VLBR07.1 the results were obtained from three antennas (Kalyazin, Urumqi and partially Simeiz), and in VLBR07.2 - from two antennas (Kalyazin and Medicina).
During processing in N. Novgorod of VLBR07.1 the rows of measurements (Doppler shift and amplitude of spectrum) were obtained for 17 space debris objects detected in Kalyazin, 7 objects detected in Urumqi and 2 objects detected in Simeiz. Moreover, row of measurements was received for Venus.
VLBR07.2 was unhappy almost in the common. Urumqi not supported it, Kalyazin worked partially, Noto was observed with incorrect BBC frequencies (schedule error), Ventspils was observed with incorrect BBC side band (LSB instead of USB), the recording from Simeiz contains internal interference peak too close to echo and this prevent to normal processing (in addition, processing of NRTV data from Simeiz displayed incorrect spectrums, while the processing of videocassettes is too long procedure). With other side, first VLBI radar useful output was obtained from Medicina. As you know, we started the development of the second LFVN correlator in Moscow, which is able to work with Mk-5 data. During last time we downloaded the data from Medicina via Internet and transformed its into NRTV format. This allowed to receive first rows of measurements for 95104 object. All obtained to time measurements were sent recently to Ballistic Center of Keldysh Institute for secondary processing. Main results of sessions of 2008 - we detected the echoes and obtained measurements for the space debris fragments at Geostationary ring, including the fragments with high area to mass ratio.
Now we concentrated on processing of VLBR06.1 experiment. We downloaded via Internet the Noto NRTV data, partially copied Mk-5 data from Zelenchuk. And now we tried to transform Mk-5 data of Zelenchuk to NRTV format in attempt to obtain few additional baselines.
The obtained results were presented at IVS meeting in St.-Petersburg in March and I will try to prepare the paper in this conference proceedings (I am waiting of some results of Zelenchuk Mk-5 data processing).
Cheers, Igor
« Ответ #6 : 28 Март 2008, 14:06:15 » |
Радиоастрономический институт НАН Украины в Харькове, ответственный за научную загрузку передающей РТ-70 в Евпатории, согласился с предложенными датами эксперимента по РСДБ-локации
« Ответ #7 : 31 Март 2008, 12:36:39 » |
Привет, Игорь!
Извини за задержку с ответом - был в командировке. Приницпиально мы готовы. Единственное, что 1-2 сентября у нас РСДБ. Поэтому Симеиз сможет начать с 3 сентября или в лучшем варианте с вечера 2 сентября. ОК?
саша
« Ответ #8 : 01 Апрель 2008, 01:01:03 » |
This is an automatically created acknowledgement.
Dear Igor Molotov, Your proposal proposal_1.tex has been submitted successfully on date 03/31/2008 21:25:54. Best regards The Proposal Staff
PROPOSAL FOR 32-M TELESCOPES AT NOTO AND MEDICINA For IRA use
TITLE: LFVN annual observations: radar measurements of space debris and solar wind research
Principal Investigator: Igor Molotov, Keldysh Institute of Applied Mathematics, Miusskaya sq., 4, Moscow (Russia)
Other Investigators (name, institution): G.Tuccari (IRA-INAF); S. Montebugnoli (IRA-INAF, Italy); M. Nechaeva (RRI, Russia); V. Agapov (Keldysh Inst. of Appl. Math., Russia); I. Falkovich (IRA, Ukraine); G. Pupillo (ISAC-CNR, Italy); Liu Xiang (Urumqi Astr. Obs.); A.Volvach (Crimean Astr. Obs., Ukraine); G. Kharlamov (Special Res. Bureau, Russia); P. Bolli (IRA-INAF, Italy); I. Shmeld (Inst. of Astr., Latvia);
Expected observer(s) Noto: G. Tuccari, P. Bolli. Medicina: S. Montebugnoli, G. Pupillo
Hours requested for this period: 60 from: Sept. 3 to: Sept. 12, number of intervals: 5
« Последнее редактирование: 01 Апрель 2008, 01:02:49 от Игорь »
« Ответ #9 : 17 Апрель 2008, 00:24:41 » |
Ура! Нам выделили запрашиваемое время и в Ното и в Медичине. Эксперименту - быть!!!
Dear Proposer, Please find below the comment of the IRA TAC on your proposal Greetings.
The IRA telescopes have been participating in this important international program from the very beginning. Both the Medicina and the Noto antennas are well equipped for this purpose. The TAC notes that this and the following proposal (9-08) should have been submitted as a single ‘coordinated’ proposal for both antennas. Also the plan of observations, in particular start and stop times, is not adequately described. The proposers are requested to contact the scheduler to define the detailed observing plan. Assigned: 60 hr.
« Ответ #10 : 23 Апрель 2008, 14:46:43 » |
Здравствуй, Игорь!
Высылаю черновик программы сентябрьского эксперимента. Получилось 5 частей по 12 часов с увеличенными перерывами (по просьбе наблюдателей Евпатории и Калязина).
Астероид удается захватить только один раз в первый день, потом он уходит из зоны видимости. Так как он маленький и достаточно далеко, то думаю, что одного скана хватит. Луна тоже видна очень короткое время на всех антеннах (вставила по скану в первый и последний день наблюдений). Из планет выбрала Меркурий (2 скана в последние дни). Предполагаю, что интервалы наблюдений можно сократить до 10-11 часов.
Маша
Draft of the VLBR08.1 schedule
The experiment consists of 5 parts and includes the radar research of asteroid 2003WT153, Mercury and objects of space debris, investigation of solar wind and flare stars observations.
7 antennas will take part in experiment: Evpatoria, Noto, Medicina, Urumqy, Kaliazin, Simeiz, Ventspils. Waveband 6 cm.
The next marking are used in the schedule:
Asteroid 2003WT153, 1 scan Space debris, beam-park, beam-track (Debris), 64 scans Solar wind (SW), 4 scans Active stars (AS), 6 scans Moon, 2 scans Mercury, 2 scans
- - - - Part 1: 3.09 (247), 06:00 - 18:00
06:00-07:00 SW 07:00-09:15 Debris (3 scans) 09:15-11:15 asteroid 2003WT153 11:15-11:45 Moon 11:45-17:00 Debris (7 scans) 17:00-18:00 AS
Part 2: 5-6.09 (249-250), 20:00-08:00
20:00-20:30 AS 20:30-07:00 Debris (14 scans) 07:00-08:00 SW
Part 3: 7.09-8.09 (251-252), 19:00-07:00
19:00-19:45 AS 19:45-06:15 Debris (14 scans) 06:15-07:00 AS
Part 4: 10.09 (254), 08:00-20:00
08:00-08:55 SW 08:55-10:25 Debris (2 scans) 10:25-11:25 Mercury 11:25-18:55 Debris (11 scans) 18:55-20:00 AS
Part 5: 12.09 (256), 06:15-18:15
06:15-06:45 AS YZCMI 06:45-09:45 Debris (4 scans) 09:45-10:15 SW 10:15-11:15 Mercury 11:15-18:00 Debris (9 scans) 18:00-18:15 Moon
« Ответ #11 : 06 Май 2008, 20:27:32 » |
Hi Carlo, CS> I updated your allocated time in Medicina on the basis of this request. CS> Please note that on Sep 9-10 there is an eVLBI experiment and CS> your observations on Sep 10 can start only at about 13:30 CS> check CS> http://www.med.ira.inaf.it/calpar.htmThank you. I see that the time after 20:00 of September 10 is free still. May be we will try slightly to move part 4 of our session? regards, Igor
« Ответ #12 : 07 Май 2008, 10:07:10 » |
Hi Carlo,
To avoid the menioned problem we propose to move part 4 of our session 9-08 (BTW, it seems that number of our proposal is 9-08, not 8-08 as indicated in schedule of Medicina):
Part 4 will be from 14:00 UT, 10.09 (254) to 02:00 UT, 11.09 (255).
Please let us know your opinion.
Regards, Igor
« Ответ #13 : 09 Май 2008, 12:14:04 » |
good! I'll change it.
About the numbering I suspect you submitted the proposal twice so it has number 8 and 9...
ciao Carlo
« Ответ #14 : 04 Август 2008, 10:27:44 » |
Dear colleagues,
I am sending the draft of the VLBR08.1 schedule. The experiment consists of 5 parts and includes the radar research of asteroid 2003WT153 (1 scan), Mercury (2 scan) and objects of space debris (64 scans), investigation of solar wind (3 scans) and flare stars observations (6 scans). Waveband of observations is 6 cm.
It is proposed, that 7 antennas will take part in experiment: Evpatoria, Noto, Medicina, Urumqy, Kaliazin, Simeiz, Ventspils.
Please, confirm your participation in the experiment. Let me know, please, if you have any remarks and questions.
Best regards, Maria Nechaeva
06:00-07:00 Solar wind 07:00-09:15 Debris (3 scans) 09:15-11:15 asteroid 2003WT153 11:15-11:45 Moon 11:45-17:00 Debris (7 scans) 17:00-18:00 Active stars
20:00-20:30 Active stars 20:30-07:00 Debris (14 scans) 07:00-08:00 Solar wind
19:00-19:45 Active stars 19:45-06:15 Debris (14 scans) 06:15-07:00 Active stars
Part 4: 10.09-11.09 (254-255), 14:00-00:20
14:00-14:25 Active stars 14:25-15:20 Mercury 15:20-00:20 Debris (12 scans)
06:15-06:45 Active stars 06:45-09:45 Debris (4 scans) 09:45-10:15 Solar wind 10:15-11:15 Mercury 11:15-18:00 Debris (9 scans) 18:00-18:15 Moon
