Автор Тема: С чем делать быструю фотометрию?  (Прочитано 15412 раз)
Хотя сейчас есть компактные и удобные PIN-диоды. В принципе, для покрытий всё равно рекомендуют трубку.
См. например http://www.optecinc.com/astronomy/ssp_main.htm
Re: С чем делать быструю фотометрию?
« Ответ #1 : Май 01, 2010, 16:09:41 »
SSP-5 Photomultiplier Tube Photometer (generation 2)
SSP-5a Automatic Photometer with 6-positon Filter Slider
The SSP-5 photomultiplier-based single channel photometer provides greater sensitivity than the SSP-3 and faster response time for occultation work. The SSP-5 has nearly 5 magnitudes greater sensitivity compared to the SSP-3. Using an optional extended red-sensitive PMT and Optec filters, the SSP-5 can provide accurate photometric measurements in the Johnson U, B, V and R bands. Optec also stocks filters for the Strmgren u v b y bands and H-beta band. Like the SSP-3, the SSP-5 has been extensively upgraded with PIC microcontroller technology and a direct computer serial interface. The SSP-5 can also be ordered with the optional motorized 6-filter slider for robotic operation. This model is refered to as SSP-5A.
    SSP Information
Navigator SSP Filters SSP-4 Details SSP-5 Details SSPDataq SSP-3 Details SSP Main  SSP4Dataq Optec has been making the SSP-5 and 5a high-precision stellar photoelectric photometer for nearly 20 years. Recently, the SSP-5 has had a major upgrade to bring the technology up to current standards. The current model is considered Generation 2. The use of a photomultiplier tube (PMT) allows fainter stars to be measured accurately and the enhanced response time of 1 ms allows fast events such as lunar occultation to be recorded with greater time resolution.
With the R6350 PMT option, the SSP-5 can exhibit an S-5 response similar to the original 1P21 photomultiplier tube. For researchers interested in greater low light sensitivity and extended red response to 830 nm, the R6358 PMT option is available. Each PMT is a 9-stage side-on low-noise photomultiplier housed in a small -inch diameter enclosure. The system is powered by a small 12 VDC universal power supply.
In spite of the fact that a PMT based photometer is more sensitive to damage from bright lights or rough handling, a great deal of effort has been expended to make the SSP-5 nearly as survivable as the SSP-3. The SSP-5 will allow the researcher to measure both bright and faint stars in the UBVRI spectral region with the degree of precision and reliability associated with the venerable SSP-3.
The SSP-5 Photometer is the central part of a complete stellar magnitude measurement system as shown in the system diagram below. This latest version of the SSP-5 features a serial output port for connection to a PC or laptop computer. An interface program called SSPDataq (freeware) is available with updated version found on the Optec web site. This program allows for data capture in any color and reduction of B and V magnitudes. The SSP-5 is intended for serious observers and it is recommended that the prospective user consult the SSP-5 manual fully before deciding to purchase
« Ответ #2 : Февраль 06, 2011, 00:23:19 »
Пишут, что к вышеупомянутому фотометру разработали специальный софт:
http://www.optecinc.com/astronomy/sspdataq2.htm
М.б. взять на пробу?
« Ответ #3 : Февраль 06, 2011, 01:23:57 »
 Не увидел в мануале главного - время замены фильтра в моторизованном "слайдере". Для нас это критично.
« Ответ #4 : Февраль 06, 2011, 01:31:38 »
Ну, так спроси у них.
« Ответ #5 : Февраль 06, 2011, 14:29:38 »
А здесь дешевенькие девайсы для спектроскопии:
http://www.starspectroscope.com/ProductList.html
http://www.starspectroscope.com/spectroscopedesign.html
1212Lupus
  • Global Team
  • Виталий
    • Наблюдение ИСЗ
« Ответ #6 : Февраль 16, 2011, 17:22:13 »
Вот пример самопального быстрого фотометра для наблюдения покрытий на PIN-фотодиоде и на лавинном фотодиоде (APD) от Джона Менке: http://menkescientific.com/photometer2.pdf
Serj
  • Global Team
  • +79099106893 Сергей
« Ответ #7 : Февраль 17, 2011, 11:25:14 »
Спасибо за ссылку, Вит! Интересный сайт.
1212Lupus
  • Global Team
  • Виталий
    • Наблюдение ИСЗ
« Ответ #8 : Февраль 18, 2011, 19:04:55 »
Да, но нигде не могу достать линзу Фабри! :'( Вроде, элементарная вещь, не требующая особой точности в изготовлении, а купить где?! Давно бы фотометр сделал на ФЭУ. Хотя нужно попробовать PIN или на APD -- может автор поделится прошивкой для контроллера...
« Последнее редактирование: Февраль 18, 2011, 19:06:56 от 1212Lupus »
« Ответ #9 : Февраль 18, 2011, 19:40:26 »
Купить можно в любой фирме, торгующей типовыми оптическими деталями - CVI, Thorlabs и т.п. Там при заказе возможен выбор просветления, как правило имеется ограниченная номенклатура кварцевых, флюоритовых и из прочих специальных материалов.
Ряды радиусов не очень плотные, так что проектировать надо уже под каталог. Каталоги большинства ведущих производителей как правило уже включены в популярные программы расчёта оптических систем, а также доступны онлайн.
1212Lupus
  • Global Team
  • Виталий
    • Наблюдение ИСЗ
« Ответ #10 : Февраль 18, 2011, 21:18:04 »
Чего-то не нашёл я каталога с линейкой линз Фабри на сайтах указанных производителей...  :-\
« Ответ #11 : Февраль 18, 2011, 23:43:20 »
Она самая обычная. Достаточно взять нужный фокус, материал и покрытие.
« Последнее редактирование: Февраль 18, 2011, 23:45:28 от AlexeyYudin »
Serj
  • Global Team
« Ответ #12 : Февраль 19, 2011, 13:36:54 »
Там вроде контроллер используется для оцифровки сигнала и синхронизации с GPS. А сам фотометр на операционниках сфелан.
Может ты путаешь линзы Фабри и Френеля?
« Ответ #13 : Апрель 24, 2011, 01:41:38 »
С марта 2011 г. ожидается начало регулярных продаж новой, чрезвычайно перспективной для видеонаблюдения метеоров КМОП-камеры PCO.EDGE.
http://www.pco.de/scmos-cameras/pcoedge/
Цена пока неясна, но совершенно ясно, что хоть она и выйдет немаленькой, уже сейчас надо озаботиться вопросами оптимальных объективов и софта, который сможет обрабатывать 5.5 Mpx/30-100 FPS видеопоток.
При шуме менее 2-х электронов такая система будет уже близка к ЭОП-ам и даже импактронам, не обладая их многочисленными недостатками.
По проницающей силе и вообще по информационной ёмкости системы это будет прорыв!
« Ответ #14 : Сентябрь 12, 2011, 03:11:14 »
Про фотометрию ИСЗ:
http://www.sat.belastro.net/glava5/glava5.1.p2.b.php
